Old 05-11-2008, 02:26 PM   #2 (permalink)
Ryland
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
Both of those scooters have a belt drive and that is going to be one of the highest matanice parts after tires, oil changes and adding gas to the gas tank, tires should last 5,000-15,000 miles depending on the quality and cost $20-70 each, the drive belt costs $19 from Honda, brakes are $18 per wheel, most things are cheap, even rebuilding the entire engine is cheap, around $300 will buy you a new cylinder, piston, rings, crankshaft, but really, the engine should last at least 30,000 miles and at that point if you spent $50 you could get it board out, go with the first over size ring set, piston and come really close to having a new engine with slightly more power, my point is, it is a low priced vehicle to own.
If you are thinking about buying something new and like Honda quality, check out the Sachs Madass, it appears to use a Honda engine only with what I think is a better automatic tranny, and if you want to you can swap in a 4 speed manual to get more speed and better mileage.
