Old 07-12-2011, 11:39 AM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I think this is what you mean, Injector DelayuS
it is a value that is defaulted to 500 micro seconds and is subtracted from every injector pulse to get the accuracy within the 1% range on most cars I've seen. It is the difference between the electrical signal and the actual starting/stopping of fuel flow within the injector.
I attempted to quantify the value with the additional delays imposed by this particular optoisolator here by adjusting it till I got back to the original fuel consumption readings with my bench tester.
Originally Posted by dcb View Post
...I would say make injUS delay at least 1000, or if you are coyotex, just dial it in with that diagnostic port
