Old 05-11-2008, 10:17 PM   #1 (permalink)
c0da
Another civic - '06 Civic LX
90 day: 40.81 mpg (US)
Aero mods on 06 civic
Workin' on mods for the civic and I'm not sure if I should leave some areas open or not. I will definitely close the whole front in the winter, but I'm wondering if these 2 air inlets that I have open are necessary or not.
The green area is where my license plate use to be and then I modified it to block the center of the bottom air intake area. Luckily there are pieces that stick out of the bottom grill from the radiator area to screw the license plate in instead of them drilling holes into the bumper.
The red area is where there are already pieces stock that block the air.
The orange area is where I plan on blocking first once I figure out a way to strap it in without damaging anything. I wanted to go with a strong plastic type that I could paint black, but it looks like people use clear plastic to block it as well and I wouldn't mind that if it was unnoticeable.
Block it all or no? Comments or suggestions on any of it are welcome.
