Thread: Low cost BMS
Old 07-13-2011, 04:18 PM   #29 (permalink)
jackbauer
jackbauer's Avatar
Likewise. I'd like to see a workable bms solution and hope this one suceeds. I like the idea of the relay disconnecting the modules when the car is turned off.
Regards the charger issue. While I understand the legality issue , I still fail to see the advantage of an isolated charger in a modern well built conversion.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
