Dremd,
On the moisture problem between the panes of glass...
I'd recommend getting a 'spray can' of Nitrogen. It's sold in paint stores and it's called 'bloxygen' I think. Painters use it to replace the air in a can of paint so it won't go bad in the can. Once the panes are dry, flush the air out with the N2 and make sure it's sealed up real good with some silicon.
Rich
