Old 07-15-2011, 06:15 PM   #8 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Elegant design, a simple and effective solution.
You might be able to improve your fuel efficiency by extending the fairing behind your helmet and back.
How is the rain protection using your leg enclosure? Do you think you could increase the coverage to make a motorcycle that can be used in the rain without soaking the rider?
How do you shift gears?
Nissan Versa Aeromods
