I think i just came up with a neat thing I can do since my CRX has a carb.. some how make a sensor that lets me know when i open the secondary butterfly in the carb... or a way totally eliminate the secondary from operation.. like a electronic lock to keep you out of the secondary that you can disengage via a switch if you need it... However this will happen after the areo mods.
Ill also be running a vacuum gauge inside for monitoring too.
