Old 05-12-2008, 10:16 AM   #1 (permalink)
tasdrouille
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
DIY OBDII to ScanGaugeII cable
I was tired of switching my SGII cable between cars now and then, especially since it's routed behind the console in the Elantra. So, I had a male ODBII connector (J1962) lying around from a dead vag-com ebay cable (VW specific diagnostic tool) and decided to make a 2nd SGII cable for cheap.
Here's the mapping between a standard CAT5 network cable and the J1962 connector
Brown - Pin 16
White/brown - Pin 15
White/orange - Pin 14
White/blue - Pin 10
Orange - Pin 7
Green - Pin 6
White/green - Pin 4 and 5
Blue - Pin 2
Facing the connector with the wide side up, pin 1 is in the upper right corner.
You could even make a SGII cable for next to nothing. If you don't have the male connector at hand you could use a junkyard female connector, extend some flattened pins made out of solid conductor power wire and tape it with the other male connector in your car.
www.HyperKilometreur.com - Quand chaque goutte compte...
