Old 07-22-2011, 12:07 AM   This thread is in the EcoModder Project Library | #1 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Stealthy injector kill switch, 6th Generation Civic
EDIT: the switch build write-up is in post #3
I'm about ready to install my kill switch for my 1998 manual trans Civic DX, but I have a question. In the picture attached, do you think the switch I bought will serve (after I remove the door jamb plate)? I am emulating this design plan: http://ecomodder.com/forum/showthrea...tml#post157489 ...but with a twist...
What I plan to do is insert the switch into the OEM (auto trans) shifter I bought (also in the picture). The 6th Gen auto had that button on the faux stick-shifter to prevent accidental selecting of reverse or park ... I'm going to slip my switch into the shifter knob. The switch from pepboys and the shifter's button housing are almost perfectly matched... the switch should work, yes? No?
