If your fog covers have no lights in them, the easiest way to block them off would be with some thin abs 1/16" some door insulated foam for the edges that touch the bumper then run som toggle bolts through it. That way you can screw them down as tight as need be, it will take the shapte of the bumper, and with no permanent damage to the painted areas of your bumper.
Or, a bit more expensive alternative would be to use vinyl to cover the hole or the paint protection film material which is clear.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
