Old 07-28-2011, 02:50 PM   #21 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Thanks for that info. I have that manual but havent read it with thought yet.
Reason is propably the eco mode switch, because I havent used it more than few test accelerations and newer on stanstill. Will try that also on tomorrow when I will drive it to Neste Rally Finland .
Used 175/80R14 tires were able to rotate on the Lupo 3L but bad noises come at turns from driveshafts so did only short test run and fuel consumtion meter showed 3.3 liter but road was now also damp due to rain than the previous todays test was 22 celsius and dry. Difference in diameter is 14% so if the fuel consumtion was 3.3 that makes it better even on rain and much wider tires. 3.0 l/100km --> 3.42l/100km. I think good diameter would be something like 8-10% taller tires. One good choice i Toyo 310 in 155/80R14 which I will most likely buy. First I need to test some tires with same diameter that will those make also the same noise.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
