Old 05-13-2008, 12:05 AM   #196 (permalink)
AndrewJ
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
Re-done grille opening.
So I re-did the grille opening today.
It was already "appropriately" sized according to the NASCAR rule of 4 square inches of grille opening per 25 horsepower.
My old grille opening was 12 square inches, and it was plenty, as long as I wasn't running beltless.
The main problem was that the radiator fan would still kick on a bit, consuming a bit of battery power every time it did so. So for running a beltless alternator, more grille opening (to reduce or eliminate running of the radiator fan) is desirable.
I increased the opening to about 4" by 4" or 16 square inches.
I also replaced the manual choke cable with some 1.5mm steel cable inside bicycle cable housing. The manual choke cable was just too stiff to make the several bends on the way from the dashboard to the airdam. (it was after all one solid strand of wire)
And here's the guts of the new grille opening, it slides horizontally in two rails, and there's a spring to help it return to the fully closed position.
And I had to replace my killswitch, I've apparently been using it a bit too much as it wore out and became very hard to switch. So a new one was in order.
I was pretty proud of myself for wearing it out
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
The Following User Says Thank You to AndrewJ For This Useful Post:
CigaR007 (07-21-2011)
