Old 05-13-2008, 03:59 PM   #49 (permalink)
mosier
grnsat - '95 SL1
metro - '95 Metro LSi
dcb:
What method did you use to calculate your microseconds per gallon?
For a DOHC Saturn, with 21lb/hr injectors I get
Code:
21.00       lbs/hr
6.25        lbs/gal gas  (~72 deg F gas)
3.36        gal/hr
17.86       minutes/gal
1,071.43    seconds/gal
1,071,428,571.43	microseconds/gal  per injector
267,857,142.86          microseconds/gal with 4 injectors?
Fuel temperature will have a big impact on the calculation, I wonder how scanguage or oem systems handle this (ignore it?).
I just put in my order, and hope to get it running on my non-obdii SL1 pretty soon..
