Old 09-01-2011, 07:52 PM   #35 (permalink)
Patrick
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
WRT aerodynamics: I think the area behind the front wheel will act as a parachute. I would round that out underneath the cycle somewhat to give the air a smooth path. The back window seems too steep - I think you will have separation there. I would bring it up higher, tapering in from the sides and ending in a Kammback if you can't get it to a point. Also, I think the area in front of the rear wheel could be improved by tapering the bodywork in (gently) as tightly as you can get to the swingarm and the tire to reduce separation there. See the attached pic for my vision of how these mods would look. Sorry about the color match - I'm not that good with Paint.
ID:	9373   Click image for larger version
Last edited by Patrick; 09-01-2011 at 07:59 PM.. Reason: Added original sketch for easier comparison.
