Old 09-04-2011, 08:53 PM   #40 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Thanks BIG Dave!
Not much snow here in Sacramento!!
exactly Brucepick.....
Somethings I have learned since kindergarden......
The polycarb product can REALLY bend and not shatter or weaken. On my first set, I used 1" squaring metal(it comes w/ the 90degree angle), that I hammered on to make about 120degrees. I had one at each end. When I bolted the end of the skirt to the metal the skirt was forced to curve at the end.
Since then I got new tires that are slightly larger in diameter.
Now I REALLY need that curve if I want to drop down all the way to where the body panel states to curve back in.
So I bought a 1.5 inch piece for the front and a 2" for the back.
I probably could have gotten the curve out of the skirt withuot a problem.
BUT
1. a wanted to aviod the 'flapping' at the center that i refered to.
2. with the metal strip, I can get the arch at the ends and keep it flat along the tire.
ps: I found out the arch in the fender, the opening for the tire is a perfect 1/2 circle (I know.....duh) I was able to layout the skirt with a string and a pen.
My first ones were not cut in a perfent curve and looked "homemade". My goal is to have these look more 'factory'.
I am going to paint all the parts the factory silver color.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
