You need to work on multiple sensors to have it working properly. The ECU will only allow the o2s to lie so much before calling it quits and going in open loop. If you hit the o2s, cts, mafs or maps, iats and tps the ECU will only see smoke.
With the iats mod (res in series to simulate colder air) alone you still get a small timing advantage though.
