Originally Posted by tasdrouille
You need to work on multiple sensors to have it working properly. The ECU will only allow the o2s to lie so much before calling it quits and going in open loop. If you hit the o2s, cts, mafs or maps, iats and tps the ECU will only see smoke.
With the iats mod (res in series to simulate colder air) alone you still get a small timing advantage though.
I am well aware of failsafing in vehicle ECU's in cars, I have several while in working here. The question is what can you get away with? I have a 1996 Ford Aspire, not very new and it isn't going to have the level of failsafing as some of the newer cars here.
I'll prolly rig something out to test this once I get a
Scangauge from the group buy to test it out. At some point it will set a fault, but I'll just reset it and increase the with a pot. I heard there is a performance Cat for my car I can put on that could help with the NOx if this works out.
