Old 05-15-2008, 02:53 PM   #9 (permalink)
steensn
The Hulk - '96 Aspire Base
90 day: 51.64 mpg (US)
Black Hole - '06 Rio LX
90 day: 39.16 mpg (US)
Send a message via AIM to steensn
Originally Posted by cfg83 View Post
steensn -
My theory is that the scangauge will be spoofed by the IAT resistor mod. It's algorithms (most likely) use the IAT sensor to extrapolate MPG.
I really gotta do that experiment. I am soooooooooooooooooooo lazy sometimes.
CarloSW2
Good point on the scangauge probably being fooled also. At minimum I can sue the pot and the scangauge to read out what the ECU thinks the new intake temp is or O2 level. I could then see how much of a gain it takes to set a fault or go into another mode where it thinks the O2 sensor is failed.
I would be concerned that not all cars are going to have the same failsafing criteria as that gets more and more sophisticated as time goes by. I can compare our failsafing from 1996 and now and I would laugh at the crude failsafing they did back then. Who knows how much you can fool it unless you test it?
2006 Kia Rio
1996 Ford Aspire
