Old 05-15-2008, 05:00 PM   #7 (permalink)
trikkonceptz
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
My sidewall max pressure says 44psi, I am running 50 psi, with no problems yet ... I am also running Nitrogen in my tires to help curve the temperature variations since average mid day temp here is now closer to 90 degrees. The ride does rely more on your suspension now because the tire is much stiffer. But other than a slightly harder ride, which I already got use to I see no adverse effect.
In fact and as an aside, I also run 50 psi in my 4 runner now and recently had a blow out, as a result of debris, I saw no additional hazard to the extra PSI other than a bit more time to get over to the side before the tire went completely flat.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
