Old 05-15-2008, 08:35 PM   #20 (permalink)
JohnnyGrey
Pushrod - '02 Cavalier
Put the resistor on a switch, go out for a drive, cruising in closed loop. Now look at your A/F meter and flip the switch. Nothing will happen to the A/F since we're in closed loop right? You won't see it jump and then be corrected right?
It will jump because it's working off of tables that have been confirmed by the O2 sensor. Then it will lean out for a second or so, then quickly be corrected by the O2 sensor back to normal. When you take the resistor out, it will go rich for a second or two, then it will go back to normal. Let me illustrate what happens when you do the resistor trick...
ECU: "Intake air is 90 degrees, I'm switching between lean and rich."
O2: "Mixture is lean."
O2: "Mixture is rich."
IAT: "Air coming into the engine just got 100 degrees hotter."
ECU: "Holy #$*#, I'd better cut back on fuel fast!"
ECU: "Let's see what my tables say I should be injecting based on the last time I dealt with 190 degree air..."
ECU: "OK, I'm cutting fuel delivery by 20%"
ECU: "I've over compensated, adjust the trim tables and increase the fuel a bit."
ECU: "I'm still off. Adjust the tables some more and increase the fuel."
ECU: "Wow, I'm really off. Injecting even more fuel."
ECU: "OK, we're back to normal again."
Everything above happens within about 2 seconds.
