Old 05-16-2008, 03:21 AM   #19 (permalink)
Ryland
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
I do a bit of my own work, I don't mount tires and have not had a problem with tires stores not wanting to sell me non stock size tires (165/70 R13 are impossible to buy around here) and I do not do alignments, any other work that is done is mostly dependent on how I feel about doing the work, how much time/money I have and if the work is going to be really hard to do without a lift or cherry picker, I swapped two transmissions my self but paid for an engine swap on my crx hf and a timing belt change on my vx, when I do take my car in to have work done I normally take it to a shop where all the work is done by the owner, he always test drives the car, gives free advice and gives a cash discount.
I tend to check over my car a few times a year, rotate tires, change spark plugs, check brakes, check exhaust mounts, set timing, check compression, change fluids.
