Well, if I trim down my demo mode so it just uses constant values I can get the 64 bit library to fit (things start breaking before you get to the maximum), so we are officially tight on space and might even need to pare down a couple things, but nobody has to write and debug and integrate any 64 bit math routines for version 1.
Binary sketch size: 14030 bytes (of a 14336 byte maximum)
