I had the debug mode on this morning as I drove into work. I pretty much saw the same results. Injector %D would jump around from 0 to 40% approximately. Although it seemed to go to a very large whole number occasionally (23456 maybe)? I don't know if that is a bug or something. The C would just jump to 0.0, 0.1, 0.2. Don't know if that is accurate but sure doesn't look like an rpm. Maybe needs to be multiplied by 10000 in the code.
Nothing with VC. I'm thinking it might be the connection circuit because I definitely get a reading with the multimeter albeit a small one. I don't think the signal goes above 0.4-0.5 Volts. What kind of signal are we supposed to get with the VSS?
