Old 09-28-2011, 08:28 AM   #14 (permalink)
d3vi1d06
Very impressive...
your leer topper... was it a tonneau cover?
also, have you considered the torque converter lockup mod?
or the Corvette syncro mod, or any transmission mod?
overall i can see maybe a 20+% increase in mpgs. 10% in just the torque converter mod alone.
research has revealed that you would need a seperate tranny fluid cooler, and remote Filter for the torque converter lockup mod. this is due to the increased heat.
also, have you considered lowering the truck? cut the front springs, and remove a leaf from the rear...
i recommend going to coloradofans.com they have lots of technical info on our trucks.
