Old 09-28-2011, 01:23 PM   #16 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
The Leer topper was their Model 100R. I don't know how the aerodynamics of that topper compare to a tonneau cover or open bed.
My topper is in four separate pieces bolted together. The front panel weighs about 5 lbs, the two side panels about 15 lbs each, and the lid about 35 lbs. The lid can be removed in 5 minutes: pull electrical connector, pop off two gas struts, pull hinge pin, and lift off. I have done it by myself, but it's much easier with a helper.
Construction is plywood glued to frames. The only metal is the bolts holding the pieces together and the aluminum hinge. All the wood is glued. The wood was sealed with epoxy inside and out, then painted white on the inside and hardware store Flame Red on the outside. It's not an exact match for the truck, but is close enough.
I am not going to lower the truck. The chin spoiler has been knocked off several times already. It's currently held on with wire ties and black Gorilla tape.
I really like the fact that I can stand bent over under the lid when it's open. That comes in useful when packing the bed full of boxes and stuff.
I've been to coloradofans.com. Got the electrical schematics from that site.
