Old 10-05-2011, 01:59 PM   #37 (permalink)
user removed
Follow mwebb's advice.
If the pad drag is equal the differential drag then you should be able to improve that.
Rebuild calipers
Turn rotors Make sure the floating pins are free and not binding.
Flush the system with new brake fluid
Make sure the brake hoses are not restricting fluid flow.
regards
Mech
