Old 10-12-2011, 07:44 PM   #2 (permalink)
MetroMPG
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Moral of the story: obviously... tire choice can have an enormous impact on vehicle efficiency!
Stuff I learned:
  • I was surprised how much better the RE92's were - not only did they have the best result overall, but they also had the biggest improvement when looking at the difference between each set of tires.
  • The spare tire/donut performance surprised me. Part of me hoped they would have magical properties. Instead they were awful.
  • PSI over 50 seemed to make little to no difference with the RE92s:
The next day I did a test of tire pressure vs. rolling resistance using the RE92's in the same parking lot. I went from 20 to 70 PSI in 10 PSI increments, 3 runs per increment. From 20-50 PSI, there was a measurable improvement each time. At 50, 60 & 70 PSI, there was no significant change in finishing position - the ending 9 chalk marks (3 PSI x 3 runs each) were mixed & clustered together along a 4.5 foot line.
I've done a test like that before: www.metrompg.com/posts/tire-pressure-rolling-resistance.htm
The Following 10 Users Say Thank You to MetroMPG For This Useful Post:
bespurcell (10-05-2015), Bicycle Bob (01-10-2012), COcyclist (09-02-2015), Crashy (06-08-2018), drees (01-03-2012), F8L (10-13-2011), JethroBodine (10-12-2011), Kodak (10-12-2011), PaleMelanesian (10-18-2011), Rick Rae (10-13-2011)
