...a series of automotive EQUATIONS worth studying:
T = 5252*HP/RPM
HP' = T*RPM/5252
HP" = (AP*CR*VE*CID*RPM)/(5252*150.8)
HP = (T*RPM/5252) = (AP*CR*VE*CID*RPM)/(5252*150.8)
VE = (T*150.8)/(AP*CR*CID)
...where:
T = torque, lb·ft
HP = horsepower
RPM = engine speed
AP = air pressure, psi (~14.7 psi)
CR = compression ratio
CID = engine cubic-inch-displacement
VE = engine volumetric efficiency, %
...use the HP@RPM and T@RPM values for your engine and backsolve for its' VE at those two operating points (remember it's not a constant, but varies with engine load and rpm).
