Old 10-31-2011, 02:53 PM   #3 (permalink)
slowmover
90 day: 19.36 mpg (US)
Have a look at fuel flow meters for marine engines ($$$, though, such as FLOSCAN). The trio of driver gauges would be:
Fuel Flow
Vacuum
RPM
Additional would be:
Airspeed
Depending on the car there are (or were) spark timing adjustment boxes (MSD, and others) where one can advance or retard ignition timing. With the above gauges (and maybe a knock sensor) can can "lean out" the engine for best cruise parameters.
Some of the "feedback carbs" worked in a similar manner.
What kind of car is it?
EDIT: I see you are aware of marine fuel flow meters.
