Old 05-18-2008, 11:40 PM   #23 (permalink)
ebacherville
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
Originally Posted by Meph View Post
couple idea:
1) over heating due to lack of airflow on the rad?
2) wheel shirts
3) maybe fill the savvy section with foam to smooth out the saggy bits?
Looking good!
Yeah ill be adding air vents to allow cooling
And filling in the sags with foam to smooth it out.. this is just the simplest way to get a nice strong shaped front end short of carving it all out of a foam block.. thats was my first idea..
Wheel skirts are next on my agenda after the nose is done.
After skirts a boat tail on the rear
As for the Trans-am comments.. slightly yes but its far more rounded than a trans am. If I wasn't required to have a front license plate I would have continued the point out more.. but need to have a place to mount the plate on the front.. so i have 7" of flat frontal area.
I may make my air intake for the radiator under the nose, as there is going to be a high pressure area there anyhow.
