you mean velcro? usefull stuff but i doubt it will hold an aluminum plate on maybe if i cut slots in it and use it to tie loops around the subframe... still it doesn't strike me as something that looks very solid...
I used plastic expanding fasteners into the existing subframe at the rear
did you drill holes in the subframe or did you use existing ones? i'd rather not make any structural alterations to such a load bearing structure... well i can't really as tech inspection would not allow it.
