Old 05-19-2008, 11:30 PM   #658 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
If you're not in a hurry, yes. We're going to pull the motor compartment apart tomorrow evening, and one of the goals is to inspect the lovejoy/splined stub shaft for play and wear. I'll measure it up and get back to you.
I'm in no hurry. Also, By the gray part I meant the part that is not visible on the clutch disk. The black part is the part that is visible before the destruction of the clutch disk.
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
