Old 05-20-2008, 12:17 AM   #4 (permalink)
Peter7307
Have a look too at the engine end of the cable. Some are adjustable to reduce / increase throttle sensitivity. By the way the car makers put them there to give the impression of more power.
You can lubricate the throttle cable but check the handbook and see what is recommended as the lubricant.
Check the pedal pivots too. These can build up and stick causing a stiff and jerky throttle.
Pete.
