Old 05-20-2008, 03:43 AM   #2 (permalink)
mattW
Engines actually run more efficiently (per kw/hp) at wider throttle angles so you can actually accelerate too slowly for FE and its better to cruise/hill climb in a high gear with open throttle then at high rpm/low throttle. You should probably look at your engines BSFC map to see where to keep the engine.
Check out my Green Cars Blog and the DIY electric car Wiki. Enjoy!
