Old 05-20-2008, 12:01 PM   #12 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Note: NOT all technique...
Car mfgr: Acura
Car model/body style: Integra LS, 3-Door
Year: 1998
Engine size (displacement/cyl): 1.8L / I-4
Transmission type (auto/manual): 4-Speed Automatic with locking torque converter and "Hill Logic Control"
MPG info:
MPG before hypermiling: 24-25
MPG currently achieved: 34
Specifics:
Location of primary driving (country/state): Kansas City Area
Miles driven per year: ~15,000
Mods/Tools:
*Max timing advance
*Winter Grille Block
*Transmission-Throttle Cable Tightened to Max Limit
*Cruise Control Throttle-Limiting System (CCTLS) (limits maximum throttle in cruise)
*Temperature-Adjustable Air Intake -- Target = 100F (WAI)
*PCV Bypass Oil Catch Bottle
*ScanGuage-II Monitoring and Feedback
*Synthetic Transmission Fluid Change
*Davis CarChip E/X OBD-II DataLogger
*Seafoam Cleanse x3 (Manifold); x1 Crankcase
*192-Degree Thermostat (170 = Stock)
*LRR Michelin MXV4-Plus XSE Tires
*Tire Over-Inflation
*OEM Engine Block Heater (with timer)
*Antenna Mod
*Exhaust manifold heat shield delete (for under-hood heat: intake, etc.)
*Splash Guard Delete x4 with underbody pans behind the rear wheels
Technique:
*Moderate Acceleration to 35 (TC lockup), with throttle-lift shifts
*Gradual Acceleration after TC lockup
*Light Timing / DWB
*DWL / Pulse-Glide (hills only)
*Corridor Effect
*Manual A/C operation when needed, or vent-only / windows cracked on highway -- down in town
*Coast, Coast, Coast...
*Minimal EOC (messes with the transmission computer and the TC lockup calcs)
*Lower Highway Cruising Speed
*Engine-off idle (if >1 Minute)
*Downshift on decel (if necessary) to keep engine speeds in DFCO range
I think that covers most of it
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
