Actually, this might not be too bad. Might also solve figuring out when the engine is off.
If in the main loop, we see that the time since injHius is getting larger than a second or so, we set a flag or whatever that says "the key is turned off". We turn off the LED backlight, and don't do anything but reset the flag on the next injector interrupt...
