Old 12-02-2011, 02:53 PM   #10 (permalink)
roosterk0031
Not trying to be critical in any way, just bouncing ideas around as you & DD are way above me in number gathering and crunching, but.
Only kind of weak spot I can see is having to use GPH with 2 decimal places to convert to gallons per 4 seconds. I bumped my fuel cost to $10 a gallon, that way TFC (total fuel consumed not Cost) gives accuracty to the 1/1000 of a gallon. Using your data loging you would see where the TFC was at start of the pluse, and at then end, find the difference and I think it would give a better amount of fuel used (elimiate a lot of rounding error).
David
The Following User Says Thank You to roosterk0031 For This Useful Post:
SentraSE-R (12-03-2011)
