Old 05-21-2008, 02:32 AM   #120 (permalink)
mosier
grnsat - '95 SL1
metro - '95 Metro LSi
Originally Posted by dcb View Post
Ah, after searching for fancy terms like "sequential" I found this:
http://www.saturnfans.com/forums/sho...9&postcount=10
91-95 - OBD1 - no cam signal, all fuel injectiors fire at the same time
96-02 - OBD2 - with cam signal, injectiors fire in order, this is sequential
i swear... i was coming back here to paste those exact lines..
that's the only time i've seen the distinction being made. over and over on saturnfans, people say the injectors fire at the same time.
now i guess i need to go back and check some things.. i'm mpfi, but since i'm running in batch, it's just like one big tbi injector firing.. that's kind of the assumption i made when i was coming up with the numbers I'd expect to see. My injector count still checks out at 36 or whatever at 60mph, but maybe my 19lb microseconds per gal, and the one i threw together for your 21lb, are way off..
maybe tomorrow i can get this sorted out..
