Why not chop the top behind the middle window? If you don't need a trunk then it's pretty easy. You could also remove and mod the rear bumper area to swing up sooner. Then the rear end will not be much longer than original. Could do mos with sheet metal like the old custom vans that had the rear door welded shut. Maybe a plexy rear window
