Not to burst anyones bubble but probably the deer has atleast one broken leg, which won't stop it from running off in the short term. Hopefully your area has some coyotes or bear to finish it off quickly.
A tip for those in deer country, if you see one cross the road in front of you, slow down even if its far away as many times there will be others following it across even if they hear your car coming.
