Old 05-21-2008, 10:50 PM   #11 (permalink)
AndrewJ
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
Originally Posted by NoCO2 View Post
How exactly did you hook up the volt meter to the batteries?
I hooked up my digital voltmeter (the permanent one) to the power and ground of my cigarette lighter.
As for my DMM when I had that hooked up temporarily, that was alligator clipped into the power and ground wires that I had for the SuperMID.
And, echomodder, be sure that you're not just "adding a 2nd battery" to your starter battery.
Starter batteries aren't up to the demands of deep-cycle use. They'll have very short and painful lives if you try to use them in an alternator-less application.
Deep-cycle batteries are designed for this type of use, and as long as you charge it appropriately, the batteries should have a long and happy life.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
