Old 05-21-2008, 11:20 PM   #3 (permalink)
AndrewJ
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
I dunno if a WAI will get you much, esp. if what I hear about the newer civics having direct injection is true.
If your car has DI, then the motor shouldn't have much restriction/pumping losses generated by the throttle body, so a WAI wouldn't be too useful (in theory)
But then again it's only theory untill someone tests it
And a WAI only involves a few $ worth of aluminum venting, so no big loss if it doesn't work.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
