I think Lexan is the name given by the manufacturer, GE maybe?
Nobody says you have to match the factory thicknesses either. I bet with some careful fitting you could use plastic windows 1/2 the glass thickness. I'd probably check your vehicle code before ordering, but I bet you could replace the hatch and rear 3/4 galss without issues.
