Old 05-23-2008, 01:25 PM   #9 (permalink)
bkrell
Big El Cheapo
big swede - '01 9-5 2.3lt
90 day: 31.96 mpg (US)
mighty mite - '09 Fit Sport
The V - '02 CR-V EX-4WD
Ody - '09 Odyssey EX-L
Welcome to the forum, Harry.
The challenge, as you've pointed out, is that you're driving an automatic. That makes it more difficult to accelerate as efficiently as a manual because you have less control over engine RPM / gear selection.
Generally I think it's good advice to advise people with automatics (who aren't doing P&G) to accelerate gently.
Andrew's spot on with the advice for hills (also known as Driving With Load): the idea should be - where traffic permits - to monitor your instant mpg at that time, and modulate the throttle to keep it above some arbitrary MPG that you want to maintain. Depending on how aggressive you are with your target will determine how much you play (lift) the throttle and lose speed on the incline.
Darin
Now this was exactly my thinking, but over on gassavers, I was chided for not looking at things correctly. I'd pointed out that by slowing down on the upslope, I was able to maintain at least 22 mpg verses around 9 mpg with cruise which was taking the engine right to the borderline between boost and vac in my saab. But I was told to not put so much stock in instant mpg which left me wondering why I bought a scangauge???
http://www.gassavers.org/showthread.php?t=7539
