Old 05-23-2008, 09:30 PM   #131 (permalink)
Mr. Cheap
Bun - '02 Focus ZTS
90 day: 31.3 mpg (US)
Enjoy your break, dcb. I'm really impatient though. I couldn't wait for you to finish your break so I wrote number 2 myself. It seems to provide more stable reading over some conditions like coasting in neutral, othertimes I'm not sure if the reading are indeed better. Maybe I need to build 2 guinos so I can compare head to head.
Strangely, Yoshi's code suggestion seems to shrink the program from 7764 bytes to 7548 bytes. ( 6914 bytes to 6788 bytes in the version on page one )
I'm now testing in a 2002 Ford Focus. I use 15500 pulses/mile (this the doubled value) and 351562500 uS per gallon. (calculated from 4 injectors of 16lb) The readings seem quite reasonable.
EDIT:
Originally Posted by diesel_john View Post
The very conservative approach Ford uses to calculate the injector size for the factory engine uses the O.E. typically safe 0.80 duty cycle limit.
So a 19 lb/hr Ford rating is at 80% duty cycle.
This would mean that my 16lb injectors are actually 20lb injectors for calculation. The uS per gallon I used was inflating the displayed milage by 25%
Update 5-24-08
I calculated that I should actually use 281250000 uS per gallon. I tested on the interstate where tests are more repeatable. I know from my fuel log that the car gets 37mpg @ 70mph and 30 mpg @ 80mph approximately. This revised calibration is very close. Mileage does vary, so I assume this is accurate data. My previous calculation was suspiciously high.
On the Caravan, I connected the wrong side of the injector due to an incorrect wiring diagram. I did actually observe a pulse when the injector turned on, but the guino would not measure the duty cycle correctly. I calibrated the fuel consumption to be reasonable, but the uS per gallon is incorrect.
Injector data : http://forums.focaljet.com/zetec-tun...low-rates.html
Ecu pinout : http://www.focusfanatics.com/forum/s...d.php?t=159134
Code:
//CHANGE THESE VALUES FOR YOUR CAR/TASTE
#define vssPulsesPerMile 15500ul
#define microSecondsPerGallon 351562500ul //injector flow rate
//#define microSecondsPerGallon 372000000ul //injector flow rate
//#define microSecondsPerGallon 2070744000ul //injector flow rate
                                        //258843000
#define numberOfCylinders 4
#define numberOfInjectors 4
#define rotationPerInjection 720 // degrees
#define tankSize 13300  //in 1000ths of a gallon, this is 13.3 gallons
byte brightness[]={0,85,170,255}; //middle button cycles through these brightness settings
#define brightnessLength (sizeof(brightness)/sizeof(byte)) //array size
byte brightnessIdx=2;
#define contrast 15
#define currentTripResetTimeout 15  //minutes
#define injectorSettleTime 15  //microseconds
//DONT CHANGE ANYTHING BELOW THIS LINE
//(well, change at your own risk anyway)
//Vehicle Interface Pins
#define InjectorOpenPin 2
#define InjectorClosedPin 3
#define VSSPin 14 //analog 0
//LCD Pins
#define DIPin 4 // register select RS
#define DB4Pin 7
#define DB5Pin 8
#define DB6Pin 12
#define DB7Pin 13
#define ContrastPin 6
#define EnablePin 5
#define BrightnessPin 9
#define lbuttonPin 17 // Left Button, on analog 3,
#define mbuttonPin 18 // Middle Button, on analog 4
#define rbuttonPin 19 // Right Button, on analog 5
#define vssBit 1     //  pin14 is a bitmask 1 on port C
#define lbuttonBit 8 //  pin17 is a bitmask 8 on port C
#define mbuttonBit 16 // pin18 is a bitmask 16 on port C
#define rbuttonBit 32 // pin19 is a bitmask 32 on port C
#define injTimeOutus 1500000ul // if injector is "open" this long then the car is off
#define backLightTimeOutus 20000000ul //time out before turning off backlight
#define loopsPerSecond 2 // how many times will we try and loop in a second
unsigned long maxLoopLength = 0; //see if we are overutilizing the CPU
#define buttonsUp   lbuttonBit + mbuttonBit + rbuttonBit  // start with the buttons in the right state
byte buttonState = buttonsUp;
//overflow counter used by millis()
extern volatile unsigned long timer0_overflow_count;
unsigned long microSeconds (void){
  unsigned long tmp_timer0_overflow_count;
  byte tmp_tcnt0;
  cli(); //disable interrupts
  tmp_timer0_overflow_count = timer0_overflow_count;
  tmp_tcnt0 = TCNT0;
  sei(); // enable interrupts
  return ((tmp_timer0_overflow_count << 8) + tmp_tcnt0) * 4;
unsigned long elapsedMicroseconds(unsigned long startMicroSeconds ){
  unsigned long msec = microSeconds();
  if(msec >= startMicroSeconds)
    return msec-startMicroSeconds;
  return 4294967295 - (startMicroSeconds-msec);
//Trip prototype
class Trip{
public:
  unsigned long loopCount; //how long has this trip been running
  unsigned long injPulses; //rpm
  unsigned long injHiSec;// seconds the injector has been open
  unsigned long injHius;// microseconds, fractional part of the injectors open
  unsigned long vssPulses;//from the speedo
  //these functions actually return in thousandths,
  unsigned long miles();
  unsigned long gallons();
  unsigned long mpg();
  unsigned long mph();
  void loadNextDummyTrip();
  unsigned long time(); //mmm.ss
  void update(Trip t);
  void reset();
  Trip();
//LCD prototype
class LCD{
public:
  LCD( ) ;
  void gotoXY(byte x, byte y);
  void print(char * string);
  void init();
  void tickleEnable();
  void cmdWriteSet();
  void LcdCommandWrite(byte value);
  void LcdDataWrite(byte value);
  byte pushNibble(byte value);
//main objects we will be working with:
volatile boolean running=true; //keep track if we are running or not
volatile boolean injectorOpen=true; //keep track if we are running or not
volatile unsigned long injHiStart; //for timing injector pulses
volatile unsigned long injLowStart; //for measuring injector duty
volatile unsigned long injOnTime; //on time for instant consumption
volatile unsigned long injCycleTime; //total time for instant consumption, rpm
volatile unsigned long vssHiStart; //for instant mph
volatile unsigned long vssCycleTime; //for instant mph
LCD lcd;
Trip tmpTrip;
Trip instant;
Trip current;
Trip tank;
void processInjOpen(void){
  injHiStart = microSeconds();
  injectorOpen=true;
void processInjClosed(void){
  injOnTime = elapsedMicroseconds(injHiStart);
  injCycleTime = elapsedMicroseconds(injLowStart);
  injLowStart = microSeconds();
  if(running==true){
    tmpTrip.injHius += injOnTime;
    tmpTrip.injPulses++;
  }else
    running=true;
  injectorOpen=false;
//attach the vss/buttons interrupt
ISR( PCINT1_vect ){
  static byte vsspinstate=0;
  byte p = PINC;//bypassing digitalRead for interrupt performance
  if ((p & vssBit) != (vsspinstate & vssBit)){
    tmpTrip.vssPulses++;
    if( p&vssBit )// compare only rising edges
    { // I wouldn't expect the vss to give exactly 50% duty cycle
        vssCycleTime = elapsedMicroseconds(vssHiStart);
        vssHiStart = microSeconds();
  vsspinstate = p;
  buttonState &= p;
void setup (void){
  pinMode(BrightnessPin,OUTPUT);
  analogWrite(BrightnessPin,255-brightness[brightnessIdx]);
  lcd.init();
  pinMode(ContrastPin,OUTPUT);
  analogWrite(ContrastPin,contrast);
  lcd.print("OpenGauge       ");
  lcd.gotoXY(0,1);
  lcd.print("         MPGuino");
  pinMode(InjectorOpenPin, INPUT);
  pinMode(InjectorClosedPin, INPUT);
  pinMode(VSSPin, INPUT);
  attachInterrupt(0, processInjOpen, FALLING);
  attachInterrupt(1, processInjClosed, RISING);
  pinMode( lbuttonPin, INPUT );
  pinMode( mbuttonPin, INPUT );
  pinMode( rbuttonPin, INPUT );
  //"turn on" the internal pullup resistors
  digitalWrite( lbuttonPin, HIGH);
  digitalWrite( mbuttonPin, HIGH);
  digitalWrite( rbuttonPin, HIGH);
//  digitalWrite( VSSPin, HIGH);
  //low level interrupt enable stuff
  PCICR |= (1 << PCIE1);
  PCMSK1 |= (1 << PCINT8);
  PCMSK1 |= (1 << PCINT11);
  PCMSK1 |= (1 << PCINT12);
  PCMSK1 |= (1 << PCINT13);
  delay(1500);
typedef void (* DisplayFx)(void);//type for display function pointers
byte screen=0;
#define looptime 1000000ul/loopsPerSecond //1/2 second
//void (*displayFunc)(void)=updateDisplay0;
DisplayFx displayFuncs[] ={updateDisplay0,updateDisplay1,updateDisplay2,updateDisplay3,updateDisplay4,updateDisplay5,updateDisplay6,updateDisplay7,updateDisplay8};
char *  displayFuncNames[] ={"Main ","Instant ","Current ","Tank ","Instant raw Data ","Current raw Data ","Tank raw Data ","CPU Monitor ", "Pulse Timer "};
#define displayFuncSize (sizeof(displayFuncs)/sizeof(DisplayFx)) //array size
void loop (void){
  while(true){
    unsigned long loopStart=microSeconds();
    instant.reset();           //clear instant
    if(running!=false){
      instant.update(tmpTrip);   //"copy" of tmpTrip in instant now
      tmpTrip.reset();           //reset tmpTrip first so we don't lose too many interrupts
      current.update(instant);   //use instant to update current
      tank.update(instant);      //use instant to update tank
    displayFuncs[screen]();    //call the appropriate display routine
    lcd.gotoXY(0,0);
//see if any buttons were pressed, display a brief message if so
      if(!(buttonState&lbuttonBit) && !(buttonState&mbuttonBit)){// left and middle = tank reset
          tank.reset();
          lcd.print("Tank Reset ");
      }else if(!(buttonState&mbuttonBit) && !(buttonState&rbuttonBit)){// right and middle = current reset
          current.reset();
          lcd.print("Current Reset ");
      }else if(!(buttonState&lbuttonBit)){ //left is rotate through screeens to the left
        if(screen!=0)
          screen=(screen-1);
        else
          screen=displayFuncSize-1;
        lcd.print(displayFuncNames[screen]);
      }else if(!(buttonState&mbuttonBit)){ //middle is cycle through brightness settings
        brightnessIdx = (brightnessIdx + 1) % brightnessLength;
        lcd.print("Brightness ");
        lcd.LcdDataWrite('0' + brightnessIdx);
        lcd.print(" ");
      }else if(!(buttonState&rbuttonBit)){//right is rotate through screeens to the left
        screen=(screen+1)%displayFuncSize;
      buttonState=buttonsUp;//reset the buttons
      //see if the engine is running or not, cars seem to hold the injector low (open) with the key off.
      unsigned long loopX=elapsedMicroseconds(injHiStart);
      if(injectorOpen==true){
        if(loopX > injTimeOutus){
          running=false;
          tmpTrip.reset();
        if(loopX > backLightTimeOutus)
           analogWrite(BrightnessPin,255-brightness[0]);
      if(running==true)
      //keep track of how long the loops take before we go int waiting.
      loopX=elapsedMicroseconds(loopStart);
      if(loopX>maxLoopLength) maxLoopLength = loopX;
      while (elapsedMicroseconds(loopStart) < (looptime));//wait for the end of a second to arrive
char fBuff[7];//used by format
//format a number into NNN.NN  the number should already be representing thousandths
char* format(unsigned long num){
  unsigned long d = 10000;
  long t;
  byte dp=3;
  byte l=6;
  //123456 = 123.46
  if(num>9999999){
    d=100000;
    dp=99;
    num/=100;
  }else if(num>999999){
    dp=4;
    num/=10;
  unsigned long val = num/10;
  if ((num - (val * 10)) >= 5)  //will the first unprinted digit be greater than 4?
    val += 1;   //round up val
  for(byte x = 0; x < l; x++){
    if(x==dp)      //time to poke in the decimal point?
      fBuff[x]='.';
    else{
      t = val/d;
      fBuff[x]= '0' + t%10;//poke the ascii character for the digit.
      val-= t*d;
      d/=10;
  fBuff[6]= 0;         //good old zero terminated strings
  return fBuff;
void updateDisplay0() {//draw the main screen
  lcd.gotoXY(0,0);
  lcd.LcdDataWrite(7); //special IN character
  lcd.print(format(instant.mpg()));
  lcd.LcdDataWrite(0); //half of the M/G symbol
  lcd.LcdDataWrite(1); //other half of the M/G symbol
  lcd.print(format(current.mpg()));
//  lcd.print(format(instant.mph()));
  lcd.LcdDataWrite(6); //special CU character
  lcd.gotoXY(0,1);
  lcd.LcdDataWrite(5); //special MI character
  lcd.print(format(tank.miles()));
  lcd.LcdDataWrite(2); //half of the TK symbol
  lcd.LcdDataWrite(3); //other half of the TK symbol
  //lcd.print(format(memoryTest()));
  lcd.print(format(tank.gallons()));
  lcd.LcdDataWrite(4); //special GA character
void updateDisplay1(void){tDisplay(&instant);}   //display instant trip formatted data.
void updateDisplay2(void){tDisplay(&current);}   //display current trip formatted data.
void updateDisplay3(void){tDisplay(&tank);}      //display tank trip formatted data.
void updateDisplay4(void){rawDisplay(&instant);} //display instant trip "raw" injector and vss data.
void updateDisplay5(void){rawDisplay(&current);} //display current trip "raw" injector and vss data.
void updateDisplay6(void){rawDisplay(&tank);}    //display tank trip "raw" injector and vss data.
void updateDisplay7(void){
  lcd.gotoXY(0,0);lcd.print("C%");lcd.print(format(maxLoopLength*1000/(looptime/100)));lcd.print(" T"); lcd.print(format(tank.time()));
  unsigned long mem = memoryTest();
  mem*=1000;
  lcd.gotoXY(0,1);lcd.print("FREE MEM: ");lcd.print(format(mem));
}    //display max cpu utilization and ram.
void updateDisplay8(void){
  lcd.gotoXY(0,0);
  lcd.print("ss");
  lcd.print(format(vssCycleTime));
  lcd.print("rm"); lcd.print(format(rpm()*1000));
  lcd.gotoXY(0,1);
  lcd.print("on"); lcd.print(format(injOnTime));
  lcd.print("ij"); lcd.print(format(injCycleTime));
//arduino doesn't do well with types defined in a script as parameters, so have to pass as void * and use -> notation.
void tDisplay( void * r){ //display trip functions.
  Trip *t = (Trip *)r;
  lcd.gotoXY(0,0);lcd.print("MH");lcd.print(format(t->mph()));lcd.print("MG");lcd.print(format(t->mpg()));
  lcd.gotoXY(0,1);lcd.print("MI");lcd.print(format(t->miles()));lcd.print("GA");lcd.print(format(t->gallons()));
void rawDisplay(void * r){
  lcd.gotoXY(0,0);lcd.print("IJ");lcd.print(format(t->injHiSec*1000));lcd.print("uS");lcd.print(format(t->injHius*1000));
  lcd.gotoXY(0,1);lcd.print("IC");lcd.print(format(t->injPulses*1000));lcd.print("VC");lcd.print(format(t->vssPulses*1000));
Trip::Trip(){
unsigned long Trip::miles(){
  return (vssPulses*1000)/vssPulsesPerMile;
unsigned long Trip::mph(){
  if(loopCount == 0)
     return 0;
  if( vssPulses == 0 )
     return 0;
  if( vssPulses < 20 )// slow speed instant
  { // the leading 2 because vssCycleTime is rising to rising,
     return 2*360000000/ ((vssCycleTime/100) * (vssPulsesPerMile/100));
  if(vssPulses<1000)
    return loopsPerSecond*((vssPulses*3600000)/(vssPulsesPerMile*loopCount));
  return loopsPerSecond*((vssPulses*3600)/(vssPulsesPerMile*loopCount/1000));
unsigned long  Trip::gallons(){
  if(injHiSec<4000) //will overflow here
    return ((injHiSec*1000000) + injHius)/(microSecondsPerGallon/1000);
  else
      return ((injHiSec*1000))/(microSecondsPerGallon/1000000);
unsigned long  Trip::mpg(){
  if(vssPulses==0) return 0;
  if(injPulses==0) return 999999000; //who doesn't like to see 999999?  :)
  unsigned long mi=miles();
  unsigned long gal=gallons();
  if( injPulses< 50 ) // instant
    gal = (( (injOnTime*10000)/ (injCycleTime/100) )*1000) / (microSecondsPerGallon/1000);
    if( gal==0 ) gal=1;
    return (mph()*10000/(36*gal));
  if( injHiSec<4 ) // prevent overflow
    gal = ((injHiSec*1000000000) + (injHius*1000))/(microSecondsPerGallon/1000); // 1e-6 gals
    if (gal==0) gal=1;//default to a millionth of a gallon so not division by zero
    return mi*1000000/gal; // 1e3 mi * 1e6 / 1e-6 gal = 1e3 mpg
  if (gal==0) gal=1;//default to a thousandth of a gallon so not division by zero
  return mi*1000/gal; // 1e3 mi * 1e3 / 1e3 gal = 1e3 mpg
//return the seconds as a time mmm.ss, eventually hhh:mm too
unsigned long Trip::time(){
//  return seconds*1000;
  byte d = 60;
  unsigned long seconds = loopCount/loopsPerSecond;
//  if(seconds/60 > 999) d = 3600; //scale up to hours.minutes if we get past 999 minutes
  return ((seconds/d)*1000) + ((seconds%d) * 10);
unsigned long rpm(){
  return rotationPerInjection*1000000 / (6*injCycleTime) ;
void Trip::update(Trip t){
  loopCount++;  //we call update once per loop
  injPulses+=t.injPulses;
  vssPulses+=t.vssPulses;
  if(t.injPulses != 0){//chasing ghosts
    injHius+=t.injHius;
    if (injHius>=1000000){  //rollover into the injHiSec counter
      injHiSec++;
      injHius-=1000000;
void Trip::reset(){
  loopCount=0;
  injPulses=0;
  injHius=0;
  injHiSec=0;
  vssPulses=0;
//LCD functions
LCD::LCD(){
//x=0..16, y= 0..1
void LCD::gotoXY(byte x, byte y){
  byte dr=x+0x80;
  if (y==1)
    dr += 0x40;
  if (y==2)
    dr += 0x14;
  if (y==3)
    dr += 0x54;
  lcd.LcdCommandWrite(dr);
void LCD::print(char * string){
  byte x = 0;
  char c = string[x];
  while(c != 0){
    lcd.LcdDataWrite(c);
    x++;
    c = string[x];
//do the lcd initialization voodoo
void LCD::init(){
  pinMode(EnablePin,OUTPUT);
  pinMode(DIPin,OUTPUT);
  pinMode(DB4Pin,OUTPUT);
  pinMode(DB5Pin,OUTPUT);
  pinMode(DB6Pin,OUTPUT);
  pinMode(DB7Pin,OUTPUT);
  delay(500);
  LcdCommandWrite(B00000010);  // 4 bit operation
  LcdCommandWrite(B00101000);// 4-bit interface, 2 display lines, 5x8 font
  LcdCommandWrite(B00001100);  // display control:
  LcdCommandWrite(B00000110);  // entry mode set: increment automatically, no display shift
  LcdCommandWrite(B01000000);  // set cgram
  //create some custom characters
  byte chars[]={ //if you squint, you can kind of see the characters below.  see the 'N' in the lower right?
  //     M/,G          T,K        GA     MI     CU     IN
    B00101,B00000,B00000,B00000,B01100,B10100,B01100,B11100,
    B00111,B00100,B00000,B00000,B10000,B11100,B10000,B01000,
    B00101,B01000,B00111,B10100,B10100,B10100,B10000,B01000,
    B00101,B10000,B00010,B11000,B01100,B10100,B01100,B11100,
    B00000,B01100,B00010,B10100,B00010,B00111,B00101,B01001,
    B00001,B10000,B00010,B10100,B00101,B00010,B00101,B01101,
    B00010,B10100,B00000,B00000,B00111,B00010,B00101,B01011,
    B00100,B01100,B00000,B00000,B00101,B00111,B00111,B01001};
    for(byte x=0;x<8;x++)
      for(byte y=0;y<8;y++)
          LcdDataWrite(chars[y*8+x]); //write the character data to the character generator ram
  LcdCommandWrite(B00000001);  // clear display, set cursor position to zero
  LcdCommandWrite(B10000000);  // set dram to zero
void  LCD::tickleEnable(){
  // send a pulse to enable
  digitalWrite(EnablePin,HIGH);
  delayMicroseconds(1);  // pause 1 ms according to datasheet
  digitalWrite(EnablePin,LOW);
void LCD::cmdWriteSet(){
  digitalWrite(DIPin,0);
byte LCD::pushNibble(byte value){
  digitalWrite(DB7Pin, value & 128);
  value <<= 1;
  digitalWrite(DB6Pin, value & 128);
  value <<= 1;
  digitalWrite(DB5Pin, value & 128);
  value <<= 1;
  digitalWrite(DB4Pin, value & 128);
  value <<= 1;
  return value;
void LCD::LcdCommandWrite(byte value){
  value=pushNibble(value);
  cmdWriteSet();
  tickleEnable();
  cmdWriteSet();
  tickleEnable();
  delay(5);
void LCD::LcdDataWrite(byte value){
  digitalWrite(DIPin, HIGH);
  tickleEnable();
  tickleEnable();
  delay(5);
// this function will return the number of bytes currently free in RAM
int memoryTest() {
  int byteCounter = 0; // initialize a counter
  byte *byteArray; // create a pointer to a byte array
  while ( (byteArray = (byte*) malloc (byteCounter * sizeof(byte))) != NULL ) {
    byteCounter++; // if allocation was successful, then up the count for the next try
    free(byteArray); // free memory after allocating it
  free(byteArray); // also free memory after the function finishes
  return byteCounter; // send back the highest number of bytes successfully allocated
