I don't know - it wasn't
SG equipped.
Make sure you won't be in any situations where you may need to steer quickly - I'd try it first (steering, engine off) away from traffic if you haven't already. You may change your mind.
Originally Posted by popimp
My question is how long is the 100 miles. Would the 100 miles reset after you started to drive again
I would say it resets. It's likely a lubrication issue -as soon as you start the engine, you're OK again. Oily bits re-oiled. (But don't sue me when it falls out the bottom of the van, OK?
