Old 01-24-2012, 09:25 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
There are already detents for neutral and the other gears, it is a ball on a spring riding on a drum of sorts. Trick is figuring out how/where to add more detents so you can feel it with your toe.
Since the bike HAS to fully disengage one gear before engaging another, there is such a position between every gear, but the vetter guy just added one between 4th and 5th (top), perhaps with a dremel and careful analysis and complete disassembly.
I've accidentally found these neutrals many times, especially when learning a new bike.
