Thread: 7000 Volts DC
Old 05-25-2008, 04:08 AM   #1 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
7000 Volts DC
After 9 years of faithful, continuous service, my HEPA filter fan finally died. It filtered it's last particle of allergens. Services will be held Tuesday.
I never used it, but it came with an "Air Ionizer" feature -- basically a series of prongs that negatively charge the outgoing air (with the idea of making particles stick to the filter media easier). The downside is heavy-duty dust sticking to the room's surfaces -- so it was never used (plus the idea of air pollution).
In an effort to repair the motor that gave out, I dismantled the unit...
Caution: Do not attempt: high voltage equipment inside.
Disassembling the unit showed the failing motor, and an interesting inverter Input: 120VAC, Output: 7000VDC-Negative. Precautions were made to ensure full discharge before removal.
Is there a practical use for this kind of high-voltage device? I got the motor working again, but the brushes are toast, so the whole thing is doomed for recycling.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
