Hey thanks guys! I was lucky to pick my GT up a couple years ago for 1 grand...Yeah my first goal is 30mpg without making the car look too crazy. My next mod will probably be a high quality ignition set-up or lowering springs, as I need to redo the suspension anyways (rebuilding the car one step at a time).
Peakster, I take it you had a fiero? The rear window is indeed a aerodynamic problem. I was looking at some of these rear window louvers (pic attached). It seems as if it would help reduce drag some and allow the engine to exhaust heat. I don't know if it would help that much but that is what this forum is about. What do you guys think?
