Old 05-27-2008, 09:15 AM   #1 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Hyperinflating tires
I'm starting a discussion thread here - and I'm hoping to move a discussion that got started when I introduced myself:
http://www.ecomodder.com/forum/showt...ires-2522.html
So hopefully this will be a bit more visible and a bit more "on topic".
First, let's define some terms:
Underinflation: Using less inflation pressure than is listed on the vehicle placard (assuming the placard tire size is being used.)
Overinflation: Using more inflation pressure than is listed on the vehicle placard (assuming the placard tire size is being used.)
Hyperinflation: Using more inflation pressure than the maximum listed on the tire sidewall.
Vehicle placard: The sticker on the vehicle that lists the original tire size and the proper inflation pressure for that size.
Agree?
Any other terms we need to define?
